LS Series Tech 1998-2002
Weights in trunk for better traction ???
Old Jan 30, 2008 | 12:06 AM
98Z28ImportSlayer's Avatar
Default Weights in trunk for better traction ???
I have a 98 Z28 camaro the only mod done atm is straight piped and im have a really bad time keeping traction wether its gasing it alittle or alot my back wheels dont want to hold traction. I have the stock 16 inch chrome rims with 245/50/zr16 Fierce UHP tires on. I was told my rear end is very light thats why my tires are spinning so much and i was told if i put 2 45 pound plates in my trunk where my t-tops go it would help traction quite a bit. Is this true ? Would i feel the affects ? any suggestions would be helpful i dont have alot of money right now so i cant do anything to huge.
Old Jan 30, 2008 | 12:31 AM
95slvrZ28's Avatar
Default RE: Weights in trunk for better traction ???
Adding weight to the rear end will help, but you also have to consider that's more weight that your car has to carry around with it. I'd suggest going with a better tire, possibly upgrading to a 275 in the process. I know that when I replaced my 245's with the 275's I have now it made a huge difference, between the better rubber and a wider contact patch you can get good results.
Old Feb 14, 2008 | 08:53 AM
whats the biggesttire (street legal)i could get for factory 16x8 wheels on my 98 z28 ?
Old Feb 16, 2008 | 03:12 AM
94 z28's Avatar
if u wanted wider tires like 275 or 295, you are going to need new wider rims, like 9" wide or 11" wide rims.
Old Feb 16, 2008 | 05:30 PM
Super charged's Avatar
What tire width should i drop on my z28 to get the best traction?
Old Mar 7, 2008 | 08:26 PM
Zoilus's Avatar
April 2009 ROTM
ORIGINAL: Super charged
The wider the better anything from 275 and up. Just make sure the rim can handle the size
Old Mar 7, 2008 | 08:30 PM
Zoilus's Avatar
April 2009 ROTM
ORIGINAL: 98Z28ImportSlayer
Don't worry about the street legal thing, there is a stupid club where people have their cars riding on 30's + wheels. So street legal is not an issue.
You need to be concerned about what YOUR rims can handle, on a 16x8 a 255 wide tire is pushing it. As mentioned you will need to widen your wheels to 9" to get the 275 + tires on there.
Old Mar 8, 2008 | 01:29 PM
JD1969's Avatar
Also remember that tire compound has as much (or more) to do with traction as width.
Old Mar 8, 2008 | 10:47 PM
im tryin to purchase some chrome z06 corvette rims that are 17x11 in the back and 17x9 in the front what do yall think of that set up ? is there a better set up i could go with ? i just want to get it right before i go out and spend $1500-2000 lol thanks for your info. guys much appreicated
tonker1
Oct 16, 2014 11:18 PM
CZimmer
Jun 3, 2012 01:25 AM
Sicksty7CamConv
Sep 15, 2010 03:16 PM
microkid
Dec 15, 2009 07:30 PM
TrammelZ28
Sep 13, 2007 06:54 PM
