LS Series Tech 1998-2002
Throttle response with the 102mm tbod.
Old Jan 10, 2010 | 11:03 PM
fbodyhemi69's Avatar
Default Throttle response with the 102mm tbod.
I'm doing a 408 superchaged stroker with L92 heads and I was wondering if I was going to loose throttle response having a 102mm tbod with the matching intake. Thanks.
Old Jan 11, 2010 | 08:59 PM
Generally, the larger the throttle body, the more air is let in for the same amount of pedal travel. This can make the car hard to drive smoothly at slow speed and in traffic unless the throttle linkage ratio is modified to slow down the throttle valve movement. Some cars have linkage that exaggerates the initial throttle movement to make the driver think that the engine is more powerful than it really is.
Old Jan 12, 2010 | 10:12 AM
So would you recommend going with the 92mm instead of the matching 102mil for better performance? what would be the best set up for power, performance, and street drivability?
Old Jan 12, 2010 | 12:15 PM
01Z28smith's Avatar
i would use the 102mm one and just adapt the linkage ratio to suit ur driving. and if u do end up buying the 102mm one u can sell me ur old 92mm lol
JakeYeah
Nov 13, 2012 04:42 PM
fbodyhemi69
Aug 13, 2010 04:34 PM
kashdog1
Jul 4, 2010 02:16 AM
purpl96
Sep 17, 2008 08:36 PM
98maro
Jan 15, 2008 01:03 PM
