LS Series Tech 1998-2002
Subframe Connectors.....
Old May 17, 2009 | 06:42 PM
SHOoffSS's Avatar
Default Subframe Connectors.....
I was planning on buying subframe connectors for my 02 camaro ss and i wasnt sure if i should buy the welded ones or the bolt ons. Which one would be stronger overall? Say if i wanted to put in a y pipe and i had welded subframe connectors in, would i have to remove the subframe connectors to put in the y pipe or is it not in the way?
Old May 19, 2009 | 08:25 AM
whammer3024's Avatar
ROTM Winner
subframe connectors wouldn't be in the way. overall, welded ones are stronger than bolt in ones
Old May 19, 2009 | 04:45 PM
Zoilus's Avatar
April 2009 ROTM
welded ones are far better and don't get the diamond style. you may have issues later on with certain exhaust set ups.
Old May 20, 2009 | 01:54 AM
SHOoffSS's Avatar
Thanks for the feedback. Definitely will get the welded ones. I wanted to anyway because they are much cheaper.
mindtwister
Oct 10, 2011 12:14 PM
RobsWreck98
Nov 3, 2008 12:13 AM
Bassplayer92
Oct 9, 2008 11:13 AM
nabisco
82-92 V8 Tech
Aug 25, 2008 07:58 PM
rockin85
Mar 22, 2008 02:19 PM
