Subframe connectors
Old Oct 23, 2008 | 01:58 PM
RobsWreck98's Avatar
Default Subframe connectors
Im lookin at getting a set for my camaro but what should i get Bolt on or weld in? The set that is two rails one for either side or the set up that looks like an H with the cross bar and the drive shaft strap? Any suggestions?
Old Oct 23, 2008 | 02:21 PM
cbr600rx7's Avatar
Default RE: Subframe connectors
I would go with the weld on.
Old Oct 23, 2008 | 03:55 PM
blackz87's Avatar
Welded SFC's...
Old Oct 24, 2008 | 08:31 PM
any recomendations on the style
With or with out crossmember and driveshaft loop?
Old Nov 3, 2008 | 12:13 AM
1969 SS's Avatar
If you have easy access to a welder, do as the other guys said and get the weld in ones. if you don't have access, just get the bolt-ins and you can always have them welded in later, for extra added strength
mindtwister
Oct 10, 2011 12:14 PM
84 Z28 Bowtie
Mar 25, 2009 06:27 PM
Bassplayer92
Oct 9, 2008 11:13 AM
nabisco
82-92 V8 Tech
Aug 25, 2008 07:58 PM
rockin85
Mar 22, 2008 02:19 PM
