LS Series Tech 1998-2002
Speedmaster procomp shaft mounted rockers
Old Jul 25, 2018 | 05:03 AM
Onsta's Avatar
Default Speedmaster procomp shaft mounted rockers
Broken Rocker
Exposed needle rollers
Making metal
I have just pull a set of PCE261.1246 Speedmaster procomp ls2-3 Shaft Mount 1.7 ratio black Aluminum rocker arm set after one broke less than 2000klm with pac1208 valve springs and 130 seat pressure.
5 sets of rockers had there needle roller cages worn through the edges exposing the needle rollers and 4 had the rocker retaining circlips wearing into the rockers making metal.
This could have been messy BEWARE!!!!
Old Jun 29, 2021 | 02:10 AM
dixkau's Avatar
I have simply pull a bunch of PCE261.1246 Speedmaster procomp ls2-3 Shaft Mount 1.7 proportion dark Aluminum rocker arm set after one broke under 2000klm with pac1208 valve springs and 130lb seat pressure. 5 arrangements of rockers had there needle roller confines worn through the edges uncovering the needle rollers and 4 had the rocker holding circlips wearing into the rockers making metal. This might have been chaotic Be careful!
snaptube vidmate
VALHAR
Oct 9, 2014 12:19 PM
ScottD
May 13, 2007 11:04 AM
350rs
Mar 7, 2007 01:53 PM
logan
Jul 24, 2006 04:52 AM
camarokid1968ss
Apr 23, 2006 12:34 PM
