roller rockers
Old Jul 15, 2006 | 06:25 PM
logan's Avatar
Default roller rockers
what roller rockers fit a 97 3.8l camaro jegs and summit keep telling me diff.
Old Jul 21, 2006 | 03:21 AM
loochy88's Avatar
Old Jul 21, 2006 | 04:01 AM
MadMikeZ28's Avatar
Default RE: roller rockers
You have to find out if you have a "rail rocker" These do not use pushrod guide plates. Or are the push rod holes small?
Also what rocker ratio. 1.5 is usauly stock and a 1.6:1 will increase lift, But they sometimes will not clear the valve spring.
I think only a roller tip rocker could be used with stock low profile valve covers also.
Other than that I believe the rockers are the same as small block V8 rockers.
Old Jul 24, 2006 | 02:55 AM
JBPickron's Avatar
could you really tell a difference with the new aftermarket rocker kit?
Old Jul 24, 2006 | 04:52 AM
MadMikeZ28's Avatar
No. not for street applications. But they make for good conversation.
jeu510
67-69 V8 Tech
Nov 6, 2012 10:42 AM
us63bravo
Apr 15, 2011 06:28 AM
rondavis
May 9, 2009 02:52 PM
sepadowd
Aug 19, 2007 11:47 PM
camarokid1968ss
Apr 23, 2006 12:34 PM
