What are the benefits of roller rockers?
Old May 12, 2007 | 10:35 PM
ScottD's Avatar
Default What are the benefits of roller rockers?
What are the benefits of roller rockers? I see them going for around 150 bucks with claims of 15-25 HP gains.Do they really increase the 'seat of your pants' pull for astreet rod, or are they best left to racing where you are trying to shave off 10ths of a second?
Old May 12, 2007 | 10:56 PM
vampyrico's Avatar
Default RE: What are the benefits of roller rockers?
to get power you need efficiency. the roller rockers have a roller. sits on the valve spring and instead of simply pushing it down and wearing on the rocker and spring. the stress on the rocker and valve is reduced by decreasing friction. while nothing is 100% efficient, this is definately an improvement. less friction= less fatigue= less heat = more power. im no expert. but thats just one reason. might be somethin else.
Old May 12, 2007 | 11:38 PM
MadMikeZ28's Avatar
Seat of your paints, I don't think so. If are running high revs and want that kind of performance then use full rollers. It used to be and may still be though you can not use full rollers on pressed in studs. You would need to have screw in studs for full rollers. If you are going to use roller tipped then use a 1.6 ratio rocker or a 1.6 intake 1.5 exhaust. It would be like installing a higher lift longer duration cam. But you also have to check and see if they will replace a railed rocker. You replaced your motor with an early one Scott so you do not have rail guided rockers. Rail guided rockers came out in 88 (?maybe?) and use a valve stem that stands taller above the valve spring.
Old May 13, 2007 | 09:56 AM
ScottD's Avatar
Thanks Mike, good to know.
Ill be picking her up from the paint shop today. I guess Ill find out if its the PCV valve or head gasket or rings when I try to drive her home.(remember all the blowbypostings...)At least she will look all nice and shiny on the back of a flat bed!
Old May 13, 2007 | 11:04 AM
350rs's Avatar
March 2008 ROTM
haha, i wish i had the money to paint mine, thats for sure. I MAY have a blown gasket somewhere myself... if so, its gona be a full rebuild i think. Not cause it needs it. But since i have the thing almost completly apart anyways... lol
us63bravo
Apr 15, 2011 06:28 AM
baseballer91
Apr 22, 2008 07:13 PM
sepadowd
Aug 19, 2007 11:47 PM
logan
Jul 24, 2006 04:52 AM
camarokid1968ss
Apr 23, 2006 12:34 PM
