LS Series Tech 1998-2002
spark plugs and wire's
Old 09-04-2006, 01:18 AM
davidalvarez82@hotma's Avatar
Default RE: spark plugs and wire's
well there has to be some thing wrong because I am burning way to much gas now I know that this is a big V-8 and its suppose to burn a lot but I went like 25 miles in all most a 1/4 of a tank and my car is all most stock except for the borla exhaust and a K&N cold air intake system and I only have 41,000 there has to be some thing wrong so do you think I should replace my plugs and wire's and maybe even my fuel filter I have a feeling that its never been changed or at least in a long time.
ORIGINAL: JD1969
Unless there is somthing wrong (like a fouled plug or burnt wire) you will not see a performance gain with new wire and plugs (at least not a measurable gain). Always remember that a dyno will show a different number on a different day (due to weather, set-up, etc)
Old 09-04-2006, 03:01 AM
Saint_Ali's Avatar
well that sounds about right they get high teens, if you think its that bad get the fuel filter checked out, and fuel pressure checked
Old 09-04-2006, 03:08 AM
thanks for the input!
ORIGINAL: Alih
Old 09-07-2006, 08:23 PM
how do you like your ac delco plugs do you think that they are better than after market plugs or worse or there really isnt much of a diffrence except for the name.
ORIGINAL: Alih
i would go with msd ignition wires and ac/delco plugs
jackss00
08-06-2011 08:10 PM
sebi1990
10-10-2010 10:24 PM
Enjoi_My95camaro
01-17-2009 09:00 AM
domo556
10-13-2008 06:34 PM
Quick Reply: spark plugs and wire's
