View Poll Results: Service Engine light is on! Help?
Leak
![](https://camaroforums.com/forum/images/polls/bar2-l.gif)
![](https://camaroforums.com/forum/images/polls/bar2.gif)
![](https://camaroforums.com/forum/images/polls/bar2-r.gif)
![](https://camaroforums.com/forum/clear.gif)
0%
O2 Sensor
![](https://camaroforums.com/forum/images/polls/bar3-l.gif)
![](https://camaroforums.com/forum/images/polls/bar3.gif)
![](https://camaroforums.com/forum/images/polls/bar3-r.gif)
100.00%
Voters: 2. You may not vote on this poll
Service engine light on
If the service light is lit, there is a trouble code set. Scan the PCM & see what the code is, otherwise keep guessing & throw parts at it. However, if you disturbed the cats and O2 sensors, you need to check your work and make sure all the stuff is where it is supposed to be.
Does the check engine light stay on or blink? If it stays lit then it usually means its a fuel, exhaust, or emmisions issue. I dont know if that helps but if you have emissions on your car maybe something isnt hooked up?
