LS Series Tech 1998-2002
Replacing the reverse lockout solenoid. Help?
Old 10-30-2010, 05:55 AM
kuyayan's Avatar
Default Replacing the reverse lockout solenoid. Help?
Searched around but cant seem to find a solution to replacing the reverse lockout solenoid. Issue came up when I scanned the check engine light a while back. Any pics would also help dramatically too! Thnx
P.s. my car is a 2000 z28 M6 if that helps.
Old 11-01-2010, 03:18 PM
Massey's Avatar
Well I can tell you where it is but I will not be able to post pictures of the thing till later if you still need them. It is on the rear of the trans at the top of the left side (driver's side) You will see 2 plugs the lower and forward most one is the speed sensor and the upper one near the rear of the trans is the lockout solenoid. One bolt holds it in. I dont know what else has to be removed to gain access but I am going to guess you may have to take the torque arm out of the way.
Massey
Old 11-17-2010, 11:54 AM
JoeBuffy's Avatar
Default Photo for you of Solenoid
Kuyayan,
I have a photo of the solenoid (PDF format so you can easily open it) but it won't let me attach anything. not sure why. If you send me a message and your email I'll shoot it over for you.
Old 11-20-2010, 04:29 PM
kuyayan's Avatar
Thnx for the help guys. Ill try to work on my car in the coming weeks i.e. winterize, preventive maintenance, and hopefully get this problem solved. Thnx again
Old 11-21-2010, 03:41 PM
JoeBuffy's Avatar
kuyayan,
I just emailed you a photo of that solenoid. Let me know if you get it.
ARROW
11-15-2015 05:38 PM
EckoUnltd.SS
02-02-2014 09:00 PM
Raven93
01-19-2014 01:47 PM
mab6680
02-23-2012 10:27 PM
KiddCamaro
04-12-2011 07:40 AM
Quick Reply: Replacing the reverse lockout solenoid. Help?
