LT1/LT4 Tech 1993-1997
purge solenoid
Old Feb 23, 2012 | 07:05 AM
mab6680's Avatar
Default purge solenoid
i have a p1441 code on my 97 z i have replaced all of the components on the evap system about a year including most of the vacuum lines ago for this same code when does the purge solenoid open im trying to test to see if its working and cant get it to open is there a way to test the solenoid to see if its working properly
Old Feb 23, 2012 | 12:48 PM
Catmaigne's Avatar
P1441 is flow through the solenoid during non purge meaning that the solenoid is stuck open. Remove the solenoid from the engine and try to blow air through it. The solenoid probably won't hold pressure because it's been gummed up by charcoal, therefore triggering the P1441 and leaking pressure into the intake manifold all the time. Your charcoal canister is falling apart so bits of charcoal are being sucked up the EVAP line through the solenoid (which is stuck open) and into your intake.
Have you ever replaced the canister? They'll go bad for 2 reasons: overfilling of the gas tank or just aging.
Old Feb 23, 2012 | 03:01 PM
grabbem88's Avatar
If you replaced the evap minus charcoal and code cleared and stayed that way for a year then I'd look at the canister as the culprit
Old Feb 23, 2012 | 03:18 PM
mab6680's Avatar
I did change the canister last year there is no charcoal in the lines and the solenoid is closed I'm trying to find out if it's opening when it's sopposed to
Old Feb 23, 2012 | 10:27 PM
2Z's
Jun 13, 2014 07:32 PM
engin70
Jun 4, 2013 02:11 PM
mab6680
Feb 22, 2012 08:51 PM
niteman
Mar 20, 2009 02:58 AM
