LS Series Tech 1998-2002
Ratchet shifter
Old Jan 9, 2012 | 07:31 PM
xXChipXx's Avatar
Default Ratchet shifter
Ive been toying around with the idea of installing a ratchet shifter. Im looking for a little more control of my car. Anyone ever messed with this. Ive researched it, but there is a surprisingly small amount of info on doing this im 4th gens.
Old Jan 9, 2012 | 09:10 PM
Failed Devices's Avatar
you want a manual valve body then right? Transgo makes them for the 4L60E, but thats the only bit i really know.
Old Jan 10, 2012 | 01:13 AM
xXChipXx's Avatar
What is the real advantage of a ratchet shifter?
Old Jan 10, 2012 | 08:19 AM
On a transmission like yours, where the computer is controlling how and where it shifts, a ratchet shifter is only a cosmetic addition. And, it'll also to make your right hand feel important. That's why F.D. asked if you're going to have a manual valve body, so you could control the trans.
Old Jan 10, 2012 | 11:45 AM
xXChipXx's Avatar
I was wondering if there wasnt much of a real gain. Has anyone had much luck with the transgo shift kit?
Old Jan 10, 2012 | 03:36 PM
Transgo supposedly makes a good product in their shift kits so i hear, but regarding their manual valve bodies I am unsure. You already have a stall which is good and gears, a manual valve body wouldnt be a bad next step for you, if you want the ability to manually control the transmission
Old Jan 11, 2012 | 10:32 PM
xXChipXx's Avatar
Im trying to decide between thw 4l60e-hd2, and 4l60e-3. Imn not really even sure what the difference is.
Old Jan 12, 2012 | 05:19 AM
mezzyshredder's Avatar
Banned
Despite what everyone is saying....here's the scoop on the ratchet shifter and how it affects your transmission. . Yes the 4L60E shifts via computer control, so, you DO NOT need a manual valve body You can control the shift points of where you want it to shift by buying the programmer which allows for adjusting the shift points. Then you use the ratchet shifter for its intended use...its purpose is to be able to "Ratchett" thru the gears with force as quickly as possible without missing any gears. The ratchett will stop at each gear so you don't accidently wind up in another gear( which would then have the transmission controlling the shifting according to the gear you would be in) or worse....you could wind up in neutral if you missed. B&M and Hurst are the industry leaders of the Ratchett. Look em up.
vXIcetreyXv
Feb 11, 2011 07:31 PM
clt1ttop
Apr 8, 2008 10:31 AM
Vtec Sucks
Dec 10, 2007 05:29 PM
gozzy341
Aug 9, 2007 01:40 PM
JoshZ28
General Racing/Tech
Nov 16, 2006 07:08 PM
