ratchet shifter/gate shifter
Old Aug 7, 2007 | 01:26 AM
gozzy341's Avatar
Default ratchet shifter/gate shifter
ive been looking into a ratchet shifter or a gate shifter for my 89 camaro. Im still a little hazey on how they work. Can i just keep it in regular drive then just throw it into manual? or do i have to keep shifting all the time? Are they basically like an old school tip-tronic (like what the volkswagons, audis, acruas, ect. have)
thank you
mike
Old Aug 7, 2007 | 01:15 PM
rs305's Avatar
Default RE: ratchet shifter/gate shifter
I had a b&m ratchet shifter in my 92 and what is does is just makes it like a manual so you can shift when you want and not skip from first to third, but you can put it in drive and drive like you always have. I never ratcheted unless i was racing or wanted to make things interesting.
Old Aug 7, 2007 | 02:49 PM
gozzy341's Avatar
hmm, would you reccomend hurst over b and m or vice versa?
Old Aug 8, 2007 | 12:34 AM
oakleys's Avatar
I hada B & M shifter handle on the four wheel drive lever in my old pick up for a while...didn't seem to help much though hahaha
Old Aug 8, 2007 | 01:58 AM
MadMikeZ28's Avatar
I had the B&M mega shifter in my 84 and did not like it. Ratcheting it down into lower gears it would hit the top of the console and push through and was not smooth acting. I put in a universal Hurst into my moms 84 S10 and it is a simpler mechanism and works much better. It does not have a handle to pull. The shifter lifts up to get out of park and push down to get into drive and ratchest into 3,2and 1.
After having a B&M I would go with a Hurst.
Old Aug 9, 2007 | 01:40 PM
gozzy341's Avatar
alright then, ill work on getting a hurst. Thanks a bunch
vXIcetreyXv
Feb 11, 2011 07:31 PM
clt1ttop
Apr 8, 2008 10:31 AM
Vtec Sucks
Dec 10, 2007 05:29 PM
creed777
82-92 V8 Tech
Mar 30, 2007 03:07 AM
