LS Series Tech 1998-2002
Pinging!
Old Apr 19, 2010 | 11:22 PM
rich1223's Avatar
Default Pinging!
My 99 SS starts to ping when i step on the throttle (just slight throttle about 1/4 not stomping it)Cruising at around 1500 rpm's and with the a/c on it much worse!I was thinking the timming might be off but i don't think so any ideas thanks!I run 93 octane all the time!
Old Apr 19, 2010 | 11:37 PM
computer adjusts the timing. probly should have it scanned for codes. could be a bad knock sensor. i think a lean condition will do it to. scan should tell more on were to look.
Old Apr 19, 2010 | 11:42 PM
rich1223's Avatar
Thanks i will take it to autozone for the free scan and see if anything shows up!
Old Apr 20, 2010 | 03:21 AM
maudyZ28's Avatar
defo running lean by the sounds or timing is off,
when the air con comes in the timing is suppose to retard I think to help with the extra load, but as it gets worse then the timing is not changing? Has it been re-mapped???
Old Apr 20, 2010 | 02:51 PM
The timing is no longer affected by the AC being on or off. That was an old cludge when computers were first used. The load is handled by the idle control system, when the AC goes on, more throttle is applied to keep idle speed steady. Check that the KS is working properly, the plugs are of the proper heat range. The timing is controlled by the PCM in response to engine load, speed, and KS input, unless, as was mentioned before the computer programming was "adjusted".
Old Apr 21, 2010 | 07:18 PM
rich1223's Avatar
I had it scanned today and its not throwing any codes.Another thing it only starts to ping when the car gets up to operating temp.EGR maybe?Anyway i was thinking of doing a complete tuneup i have only had the car over a month and a half maybe the plugs have never been changed.Hopefully that clears it up.
Old Apr 21, 2010 | 10:49 PM
383Stro's Avatar
What kinds of tuning has been done to the car? Because that pinging could be pre-ignition or detonation. Pinging is an interesting way to describe it. Pull at least an easy plug to reach and read it just to be safe!
manslaughter299
Jun 21, 2012 09:56 AM
Wjhpc
Jan 12, 2012 01:36 PM
imcdowel
Dec 8, 2010 02:34 PM
z28ya
May 21, 2008 12:29 PM
Saint_Ali
Sep 25, 2006 12:11 AM
