LS Series Tech 1998-2002
Octane Change?
Old Jun 24, 2007 | 06:48 PM
Deagle85's Avatar
Default Octane Change?
Hey guys, I'd like to change the octane I've been using from 89 to 91. Whats the easiest way to do this? I'm thinking to just get the tank on E and then fill it up with 91? Any advice would be great, thanks
Old Jun 24, 2007 | 08:14 PM
JD1969's Avatar
Default RE: Octane Change?
Just start putting the 91 in. With the compression the LS1 has, you should have been running at least 91 from the start.
Old Jun 25, 2007 | 05:51 AM
Deagle85's Avatar
What do you mean by compression?
And what kinds of changes will I get with 91? Anything noticeable?
Old Jun 25, 2007 | 10:07 AM
Lee Willis's Avatar
The engine's compression ratio is beyond 10:1, so its needs higher octane fuel. I think 91 is the minimum that should be used.
Just start putting 91 or 93 octane in the tank and using that.
Old Jun 26, 2007 | 05:55 AM
Deagle85's Avatar
Roger that, thanks
Old Jul 3, 2007 | 04:18 PM
bluovlh8er's Avatar
what does a 3.8 call for?
Old Jul 4, 2007 | 08:01 PM
94Red's Avatar
if im not mistaken 3.4 and 3.8's say go for the 89octane
Old Apr 27, 2008 | 12:12 AM
libertyforall1776's Avatar
I put 87 in my 3.4L, and 91 or sometimes 89 about every third tank in my SS -- AFAIK, if you get a knock, then you best raise the octane. I am not aware of anything detrimental apart from that condition...
Old Jun 5, 2008 | 02:39 PM
COJO_24's Avatar
what octane is premium gas....92??
Old Jun 6, 2008 | 05:04 PM
95slvrZ28's Avatar
Wow...dig up a long dead post...anyway...
Premium fuel ranges from 91-93 octane depending on your altitude. You should always run premium in an LS1 because it is a high compression motor. If you run lower octane the computer will start to pull timing because it will detect engine knock, and thus you'll experience a loss in power.
valnzula
Jun 23, 2010 09:25 PM
LHill00Z28
Oct 3, 2009 12:36 AM
z28joeyg9
Apr 8, 2009 12:28 AM
wildcatman01
Mar 1, 2009 02:31 PM
Saint_Ali
Sep 4, 2007 02:07 AM
