Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
What Octane Do I Need?
Old Feb 25, 2009 | 01:49 PM
wildcatman01's Avatar
Question What Octane Do I Need?
I am currently in the process of blue printing my engine that i am going to build for my 79 camaro z28.
I am using an 64 to 66 283 cid with a 3.25 stroke. I have calculated my static compression ratio to be 10.2:1. I am having trouble figuring out what octane to start out with. If anyone can point me in the right direction it would be appreciated.
Depending on what i can figure out with this i may also contemplate running on E85!
Old Feb 25, 2009 | 03:14 PM
robmnrd's Avatar
Well, I'd suggest running premium. But you could start with regular, and if you get some pinging/knocking switch to mid. If it continues, put in premium. If it keeps going, put in some 110! :P If it STILL does it, you've got issues. haha
Old Feb 25, 2009 | 03:29 PM
SpecterGT260's Avatar
Ninja Administrator
if it still pings after that, u put ur cam position sensor in backwards lol
no.... not really
I recommend running premium for pretty much anything other than stock. its just me, i dont like to risk my components. 110 will most likely be overkill for what ur doing. 10.2:1 isnt that crazy. a good 92 will probably do u just fine. im sure there are calculators out there. can you adjust timing by hand? start with a mid grade, see if you have knock, if u do back the timing down until u can fill up with something better
Old Feb 25, 2009 | 04:18 PM
You definitely don't need more than premium. You may even get away with using mid-grade. I used to have a 69 Vette, 350 with 10:1 c.r. and I never got a ping from using mid grade. I alternate between mid and high (every other tank) with my Camaro with no issues, and it's c.r is in the high 10's.
And if you're going with aluminum heads, they'll be more forgiving in the octane department.
Old Feb 27, 2009 | 05:45 PM
zaxroom's Avatar
I never got a ping with regular but I switched to plus because I got about five miles to the gallon then with plus I got way better performance and eight to ten miles per gallon.
Old Feb 28, 2009 | 08:58 PM
Lee Willis's Avatar
Ifyou have iron heads, and I am guessing you do witha 283 if you are being true to the original, premium will be the only fuel you can really use.
Old Feb 28, 2009 | 11:09 PM
lt4weeda's Avatar
Just go to the nearest airport and fill up. Always makes a good sight in my town. You get all of the old farmers and their crop dusters and your fillin up your car. Plus then you can say that your car is so fast you have to fill up with rocket fuel haha
Old Mar 1, 2009 | 01:42 AM
Originally Posted by lt4weeda
Just go to the nearest airport and fill up....
You talking about using AV fuel? Not a very good idea, unless you like to periodically open up the engine and clean out all the crusty crud you'll be getting built up in the cylinders.
And, jet fuel is pure kerosene.
Old Mar 1, 2009 | 02:06 PM
zaxroom's Avatar
And Naphtha, you could always throw in some acetone to increase the octane. Between Kerosene and a little acetone you can get some high octane fuel. The kerosene reduces the flash point of gas and the acetone helps to atomize the gas. I you look at most octane boosters they will say that is contains kerosene, it is also good for cleaning your fuel system in small amounts. Be careful with the acetone because if you have cheep plastic parts in your fuel system it will dissolve them other than that it works great.
Old Mar 1, 2009 | 02:31 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
I am with Spec, I put premium in anyways. I see an increase in gas millage and the price difference is made up by that.
valnzula
Jun 23, 2010 09:25 PM
z28joeyg9
Apr 8, 2009 12:28 AM
fetuswrangler
Nov 20, 2008 09:39 PM
Saint_Ali
Sep 4, 2007 02:07 AM
