100 octane
Old Aug 31, 2007 | 10:45 PM
Saint_Ali's Avatar
Default 100 octane
is it better to run 100 octane in an lt1 ? or would it damage the engine ?
Old Aug 31, 2007 | 10:58 PM
riceeater's Avatar
Default RE: 100 octane
I would stay at 93, but 100 wont hurt it.
Old Aug 31, 2007 | 11:13 PM
8485Chevycowboy's Avatar
i run a 15gal to 1gal....... 15gals91oct and 1gal 111oct and it hasn't hurt one bit
Old Sep 1, 2007 | 12:14 AM
MadMikeZ28's Avatar
ORIGINAL: 8485Chevycowboy
What do you think you are getting from that? If you went 50/50 you would just be getting 101 octane. But you don't do that. You run less 111oct so its not increasing the 91by anything really.
Old Sep 1, 2007 | 02:06 AM
SpecterGT260's Avatar
Ninja Administrator
just dont run leaded fuel. it WILL damage engine sensors. as for octane, the higher the "better", however a stock or even midly modified engine wont make any use of the extra anti-knock capacity. Thats all octane really is. unless you are running a huge nitrous shot, boost, or lots of timing i would say forget it and just run 91-93 depending on what you have available.
Old Sep 1, 2007 | 09:53 AM
The car was optimized by the factory to run on premium. Using 100 octane won't hurt as long as it is unleaded, but because the engine does not have the compression to utilize the extra octane of the slower burning fuel, andit may wind up making less power. In any event, 100 octaneit is a waste of money on a stock engine, even if the spark timing is optimized for it. You can only use so much spark advance, even if there is no spark knock, before the engine starts losing power instead of making more.
Old Sep 1, 2007 | 10:22 AM
bluovlh8er's Avatar
i use 89 in my lt1, good or bad????????????
Old Sep 1, 2007 | 11:51 AM
t9ojetpilot's Avatar
[&:] bluovlh8er youll need to listen to the engine. if you drive like grandma you may get away with the low or medium octane and avoid detonation. if however you drive like the rest of us lt1 owners and use the power on tap once in a while id recommend the 91-92 octane to avoid the destructive detonation. in my experience this is what the engine likes to eliminate any spark knock kurt
Old Sep 1, 2007 | 04:16 PM
Ninja Administrator
the lt1 should have the ability for KR. you probably wont hear knock, but you will lose power with low octane as the computer pulls timing
Old Sep 1, 2007 | 07:42 PM
Iceman1023d's Avatar
what about in my 3800?
