LS Series Tech 1998-2002
ls1 information
Old Feb 19, 2009 | 08:26 PM
  #21
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
You are getting PM's on this?
Old Feb 20, 2009 | 08:14 AM
  #22
whammer3024's Avatar
ROTM Winner
not this in depth no, but i did have a kid asking me what cam to use in his ls1 and i had no idea. i figure the more i learn about these cars the better
Old Feb 20, 2009 | 01:11 PM
  #23
95slvrZ28's Avatar
Originally Posted by Saint_Ali
my buddy has a 99 z28 with a hot cam, and the ls1 hot cams are a lot bigger then the lt4 hot cam
The cams on an LS series motor is always more extreme than that of the traditional SBC. You can get a lot more lift out of the LS series.
Old Feb 21, 2009 | 11:21 PM
  #24
traumadog's Avatar
Originally Posted by 0235thcamaro
...What's cool is all these thing are interchangeable.
Right, but only for the LS1 vs LS6...
The LS2/LS3/LS7/LSX can also accept LS1-based mods, but because the bore size is bigger (4.06" vs. 3.9") in the Gen IV blocks, those heads (e.g. the new L92 heads) have larer valves and won't fit on the smaller LS1/LS6 blocks.
Also, there are other minor differences - such as fly-by-wire on the later blocks, as well as different ECM's with differing reluctor wheels for timing.
Old Feb 21, 2009 | 11:51 PM
  #25
SpecterGT260's Avatar
Ninja Administrator
^^^ true story.
I just posted a thread about a 500ci ls2 based engine which uses ls7 heads and intake.
Old Feb 22, 2009 | 08:02 AM
  #26
cbr600rx7's Avatar
You can also use 317 LS2 heads on a LS1 this would allow use of the LS3 and LS7 type intakes
Old Feb 22, 2009 | 08:11 AM
  #27
cbr600rx7's Avatar
Originally Posted by 6v49der
Lol, wrong already, an LS1 is 346 cubic inches. Besides that, from what I understand the LS1 can take a little upwards of 500 hp, maybe 550 or so before it becomes physically impossible for the engine to handle its own power. Ive never seen the bottom of one to tell you for sure but apparently they are only 2 bolt mains. Perhaps someone with a little more engine building knowledge could help here.
A lot depends on the set up and tune. 500 to the wheels would be a little low. Once you get into the high 5## and into the low 600s is where you will start needing to replace parts. Pistons will be the first limiting factor. The rods can handle a little more and the crank can take a beating from hell its self with good rod bolts. A lot comes down to set up and tune. If i was planing on running more the 550 or so to the wheels i would go ahead and at least do good pistons, rings, bearings, and rod bolts and have the crank polished and every thing balanced up real nice if i was trying to work on a budget that should allow any one to run well into the 600s with out any issues all day long. However as said above there are more then a hand full of guys running in the 600 both on FI and Nitrous set ups that are running bone stock bottoms.
Old Feb 22, 2009 | 08:27 AM
  #28
cbr600rx7's Avatar
ls1=for men with small *****
So i see your angry. But its ok. One day you will learn to live with the fact that you picked an out dated platform and learn to live with your self and except the LS1 as your guiding light to the future.
And need i remind you...
Old Feb 22, 2009 | 04:50 PM
  #29
Ninja Administrator
i did not know that.... i only ever see 5.3 heads and 243 castings (ls6) swaps. as the guy above me said, the bore is larger so gen4 parts wont work unless u match the bore.
Old Feb 23, 2009 | 08:48 AM
  #30
ROTM Winner
now cbr...i started this thread and i'm an LT1 guy...so don't come into it talking crap about lt1's.
thanks for all the info guys. i didn't really realize you guys could get up to 600hp on stock internals. that's pretty nasty. oh and spec...i got something planned for you to take a look at in the future...give me some time my friend
