LS Series Tech 1998-2002
Which injectors?
Old Jul 26, 2011 | 03:34 PM
xXChipXx's Avatar
Default Which injectors?
I had my car dynod today and they said it started cutting out at 6000 rpm so it only made 380hp. Any suggestions for injectors?
Old Jul 26, 2011 | 06:11 PM
Does the dyno chart show the engine leaning out? Have you had the computer tuned after changing cam? If not, the engine may cutting out beacuse it is hitting the rev limiter.
Old Jul 27, 2011 | 04:41 PM
xXChipXx's Avatar
It was being dyno tuned.
Old Jul 29, 2011 | 01:12 PM
In that case the tuner person should know what size injectors will work best.
Old Aug 18, 2011 | 03:26 AM
maudyZ28's Avatar
I think on a 98 you should have the 28lb/hr injectors, at a low AFR you should only be at 80% duty cycle so the injectors should NOT be topping out? Just posted in your dyno thread too, you need to ask the tuner what AFR the cars running
Old Aug 18, 2011 | 08:36 PM
SYDEWAYZSS's Avatar
what did they charge u for the dyno tune??
Old Aug 24, 2011 | 04:10 PM
Slo LS1's Avatar
Since its a cam car get your stockers resized to like 42lbs at corvetteinjectors.com
But your logs should tell you what your IDCs are.
Old Sep 25, 2011 | 05:59 PM
cbr600rx7's Avatar
You should not be coming any where close to maxing yet. Could be the pump getting weak. I do have a set of 8.1 injectors if you are in the market. Also you can pick up RED top SVO injectors cheap as well.
lt1z2896
Mar 6, 2010 05:52 PM
Cris
Jan 24, 2010 03:48 PM
joeSScamaro
Sep 4, 2007 02:49 PM
8485Chevycowboy
Jul 11, 2007 03:45 PM
sepadowd
Jun 15, 2007 08:50 AM
