Which injectors?
I had my car dynod today and they said it started cutting out at 6000 rpm so it only made 380hp. Any suggestions for injectors?
Does the dyno chart show the engine leaning out? Have you had the computer tuned after changing cam? If not, the engine may cutting out beacuse it is hitting the rev limiter.
It was being dyno tuned.
In that case the tuner person should know what size injectors will work best.
I think on a 98 you should have the 28lb/hr injectors, at a low AFR you should only be at 80% duty cycle so the injectors should NOT be topping out? Just posted in your dyno thread too, you need to ask the tuner what AFR the cars running
what did they charge u for the dyno tune??
Since its a cam car get your stockers resized to like 42lbs at corvetteinjectors.com
But your logs should tell you what your IDCs are. |
You should not be coming any where close to maxing yet. Could be the pump getting weak. I do have a set of 8.1 injectors if you are in the market. Also you can pick up RED top SVO injectors cheap as well.
