LS Series Tech 1998-2002
heads
Old Aug 26, 2006 | 02:52 AM
o2camaross's Avatar
Default heads
is it possible to put LS6 heads on a 02 LS1? if possible what other modifications would i have to make or should i make and what kind of gains would i be expecting from heads and possible a cam. also what kind of heads and cam do i want? thanks
Old Aug 26, 2006 | 05:38 AM
2002CamaroSSM6's Avatar
Default RE: heads
I posted a thread up awhile ago when we discused the ls6 conversion kits for the ls1. If you go to summitracing.com and look up the ls1 to ls6 conversion you'll find a kit that comes with heads and a cam for about $1700 it brings your horsepower rating to over 400. Its a badass kit and some serious power for the buck. and JD1969 said with a little more cam you'll have some serious horsepower.
Old Aug 26, 2006 | 11:30 AM
JD1969's Avatar
Default RE: heads
The LS6 heads will bolt right on, but personally I would just go for the AFR heads they flow more and will make more hp (if thats your goal). A cam and heads LS1 will make well over 400rwhp if all the parts are matched correctly.
Old Aug 26, 2006 | 10:47 PM
o2camaross's Avatar
Default RE: heads
thanks for the info
Old Aug 26, 2006 | 11:05 PM
o2camaross's Avatar
Default RE: heads
i was looking on summit and i saw the GM conversion kit then i kept looking around and i saw a patriot Stage 2 head and cam package. check it out. http://store.summitracing.com/egnsea...12944&D=312944
it comes with the shaft mounted roller rockers and its the same price. which one would give me more power and which one would be of higher quality and last longer? pleasse help. thanks
Old Aug 27, 2006 | 12:32 AM
JD1969's Avatar
Default RE: heads
The Patriot package will out-perform the GM kit by at least 50 hp
fbodyhemi69
LS Series Tech
Dec 7, 2009 05:16 PM
SixShooterCamaro
Oct 30, 2009 08:58 PM
Red Demon
Oct 25, 2007 02:29 PM
1983_JAL
Mar 23, 2007 11:57 PM
