LS Series Tech 1998-2002
Growling noise
Old 03-21-2011, 09:49 AM
Barbs 2001 SS's Avatar
Default bearing noise
I've had the same noise (sounds like rear bearing). The car is a 2001 with only 31,000 miles on it. I thought about checking or changing the rear bearings, but I just can't believe they would be bad at that mileage. So I'm hoping it's maybe just a camaro thing. It doesn't seem to be getting louder so I'm just going to keep driving it, I'll leave a post on here if something does give out. Barb.
Old 03-21-2011, 03:49 PM
z28?SS?'s Avatar
That growling noise never really got worse for me either, but I can assure you that it is the diff. bearings. Its not about age per say, but instead whether or not the rear differential was put together bad, which if it was, causes too much pressure on the bearings causing them to go bad. I wouldn't advise driving on it too long.... if it gets bad enough it might cause your whole diff. to get messed up.
B_Dubya
03-27-2015 02:10 PM
DashingDaryl
04-04-2012 02:46 PM
AKLDan2k1
08-23-2011 07:56 AM
supreme_style21
06-08-2010 06:36 PM
EddieTheRipper
10-11-2007 08:57 PM
Quick Reply: Growling noise
