LS Series Tech 1998-2002
Gears, 02 Camaro
Old Apr 11, 2012 | 07:55 PM
Chevra's Avatar
Default Gears, 02 Camaro
What is the stock gears that come with an 02 SS? In the previous topic I had open I got the idea that it was 2.73 gears, but I have a Diablo Trinity tuner and when I am sitting there idling it is showing 3.05 ratio. Is this what I have then? Thanks.
Old Apr 11, 2012 | 09:04 PM
Failed Devices's Avatar
Do you have an auto or manual? All Manual cars came with 3.42. Autos had 2.73 with an option of 3.08 (might have been 3.23).
check your rpo code
Old Apr 11, 2012 | 09:11 PM
Chevra's Avatar
I have an auto. And yes im sorry i was wrong the programmer is showing 3.08 so that must be what I have.
Old May 2, 2012 | 08:47 PM
cbr600rx7's Avatar
It could also be a 3.23
Old May 2, 2012 | 08:51 PM
cbr600rx7's Avatar
You should be able to look at the RPO code located on the inside of the driver's side door jam.
GU2 = 2.73
GU4 = 3.08
GU5 = 3.23
GU6 = 3.43
G80 Rear limited slip
Old Jun 5, 2012 | 10:11 AM
mezzyshredder's Avatar
Banned
You can upgrade for cheap though
Old Jun 5, 2012 | 10:15 AM
Banned
You can buy the gears from anywhere for like $225. You need to specify 2 or 3 ring carrier. I believe all 2.73,3.08 and 3.23 are all 2 ring carriers, while all the rears that came with the 3.42s, were 3 ring carriers.
mike88
Aug 23, 2011 04:37 AM
69SS427
Jan 2, 2011 06:06 AM
Dillon5224
Feb 15, 2010 03:54 PM
nuggetray
Mar 20, 2009 12:13 PM
