LS Series Tech 1998-2002
Engine Swap Writeup?
Old Mar 30, 2007 | 02:48 PM
Norvak's Avatar
Default Engine Swap Writeup?
I am curious if I can find any info on a webpage that would list everything involved in doing a 350 engine swap on a 1999 Camaro. Currently has a v6 with a 5speed, all stock.
I did a search and found info for earlier generations, but not exactly what im looking for.
Old Mar 30, 2007 | 08:31 PM
JD1969's Avatar
Default RE: Engine Swap Writeup?
Unless you go fuel injected (IE LS1 swap) you will have a very hard time finding an intake/carb combo that will fit. The engine sits half under the windshield, you can fit some carb/intakes under there but it usually ends up being a very hack job. An LS1 swap would need the engine, trans, engine mounts, exhaust system,trans x member, engine and trans wire harness, torque converter or clutch, radiatormaybe the drive shaft and the rear end will need to upgraded at some point. It is a total bolt in deal with little to no fabrication. Much of this stuff would be needed for any V8 swap.
Old Apr 9, 2007 | 06:31 PM
Saint_Ali's Avatar
yeah it would be a lot lot cheaper to just find a newer camaro with a ls1 in it
3800_seriesII
Aug 14, 2012 07:24 AM
bigchevyman24
Jul 31, 2009 01:27 PM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
Bennyt900
Aug 27, 2006 05:10 AM
warthor
Aug 27, 2006 04:56 AM
