LS Series Tech 1998-2002
clutch problem?
Old Jan 5, 2007 | 12:56 AM
Z28insc's Avatar
Default clutch problem?
i was showing my friends how badass and ls1 is but i had a problem. i like to think im good a driving a clutch but correct me if im wrong. while i was getting on it i changed from 2nd to 3rd and my cluth stuck half way to the engaging point and the release point. what did i screw up?
Old Jan 5, 2007 | 12:20 PM
shnormo's Avatar
Default RE: clutch problem?
It could be your slave cylinder or the master cylinder with a leak or maybe the system is low on fluid. You could have a bad finger on the pressure plate or blew a spring on the clutch itself.
Old Jan 5, 2007 | 05:11 PM
nitrojunkie's Avatar
I saw a TSB about this. They used the wrong retaining clip or something on a few years of camaros. This causes a scraping sound as the pedal is depressed/released or stuck pedal. The dealer should replace it for you.
Beest
Jun 27, 2010 02:42 AM
BUTTHEAD
Jul 1, 2009 11:59 AM
whatsupdoc
May 26, 2008 06:11 PM
Rise65
Nov 8, 2007 10:58 PM
