LS Series Tech 1998-2002
Best Springs/suspension, and brake problem?
Old Jul 1, 2009 | 10:29 PM
jbcamaro's Avatar
Default Best Springs/suspension, and brake problem?
My 01's starting to squeak over every bump go over and everytime i even move the car, so ive decided just to get them lubricated. And also when i slow down its not a smooth stop its like it brakes every half a second or something? ive tried braking with it in neutral with clutch in, clutch out, its still all the same. My brakes pads are still pretty good tho, and no squeling from them, only my suspension. idk why it would do it?
Also wondering, going to upgrade the suspension what would be some good brands and ideas on what to do?
thanks.
Old Jul 1, 2009 | 11:30 PM
sounds like the rotors need turned. struts and bushings may be gitting old and starting to sqeek. i have koni yellows on mine and are very nice. check out s strano website and if u like give sam a call and talk to him. he can set u up however u want it.
http://www.stranoparts.com/partsmain.php
Old Jul 12, 2009 | 04:06 PM
oakwood69's Avatar
Default miles?
i have a similar problem and had my rotors turned twice, not the rotors. i think its worn balljoints and bushings too. how many miles do you have? i have an 02 with 156000.
Old Jul 14, 2009 | 01:38 AM
jbcamaro's Avatar
i only have almost 90,000, but im going to replace all the rotors and pads because they need it anyways. I ll see if that works, hopefully.
Old Jul 20, 2009 | 03:52 AM
oakwood69's Avatar
it will, i just got done rebuilding my balljionts and upper and lowers control arm bushings and my brakes dont wobble anymore.
Old Jul 21, 2009 | 10:19 PM
jbcamaro's Avatar
i replaced all my rotors and pads, (pads have never been replaced) solved the problem for the braking. As for the suspension, wat do some of u guys have on your cars suspension wise? because i dont know much about suspension..
Old Jul 21, 2009 | 10:30 PM
still squeeking?
Old Jul 23, 2009 | 04:19 AM
oakwood69's Avatar
bilstein struts and shocks and hotchkis suspension components.
Old Jul 26, 2009 | 09:44 PM
jbcamaro's Avatar
my brakes arent, my suspension still is.
Old Jul 26, 2009 | 09:58 PM
do some research on struts and shocks for the car and see what u can afford. if u checked out stranos then u know a set will run from a few hundred to a thousand bucks depending on what u get. if u call and talk to sam u will get what is known as service. something not so common nowdays. it may take a few calls to get threw but its worth it. tell him what u got going on, i think ull be happy.
cozen89
Apr 11, 2015 12:34 PM
carid
Vendor Special Buys
Feb 10, 2015 09:06 AM
keefer80z28
Dec 28, 2014 02:24 PM
Gorn
Feb 3, 2012 06:37 AM
x01660
Aug 1, 2011 11:02 PM
