LS Series Tech 1998-2002
A4 VS M6
Old Jan 8, 2009 | 04:24 PM
importmd's Avatar
Default RE: A4 VS M6
t5's are junk, they cant even hold up to a stock 305. 4l60's are weak, the 4l80 is a heavy duty auto trans
Old Jan 8, 2009 | 06:49 PM
Redneck97's Avatar
yea my t5 is junk so is my rear end....
Ive gone through one rear end one trans.....but the motor is holding strong at 175k miles woot.[8D]
Old Jan 10, 2009 | 07:50 AM
02z28maro's Avatar
is there any proof of the t56 taking over 600hp?
Old Jan 13, 2009 | 03:28 PM
Zoilus's Avatar
April 2009 ROTM
ORIGINAL: 02z28maro
Yeah everywhere. Im sure people on here have or go to LS1tech or CamaroZ28.com. There are tons of people who are hitting that range without any problems to the trans. The T56 is the breaker of rear ends, and more than likely thats what will go b4 your tranny and at 600rwhp I wouldn't be worrying to much about the trans more than I would be worrying about your internals making a break for it from the confinement of the engine compartment!
Oh and for a few months I had a drykit on. I was making/still make470 N/A at wheels and was hitting 568 with spray and the only issue I had was my gas needle was magically drawn to the "E" ....alot!
Old Jan 25, 2009 | 07:57 PM
JD1969's Avatar
I am running a stock 4L60E with a Yank 4000 stall and a big trans cooler. Three years of running well into the 11's and pulling 1.5 60 foots and it is 100% fine. The T56 broke with less than 400 rwhp. Plus the T56 is not really a very good trans for drag racing as the ratio in 1st does not help to launch the car.
Old Jan 25, 2009 | 08:09 PM
cbr600rx7's Avatar
^^^^ Both of them are dead on. The T56 is a rear killer, it is stronger the the 4L60 but is not by any means the best transmission to be using for drag racing. The transmission that is in my car right now is the factory 4L60 with 91,000 miles on her. I have probably 60 passes on the transmission plus a few hard cone runs on her as well. The car has had two different nitrous kits and the factory trans has held up perfect. In a few weeks when we pull her out i plan on keeping her around for future projects and i have no question she will still run like a champ.
Old Jan 25, 2009 | 08:11 PM
cbr600rx7's Avatar
What trans cooler are you running?
Nice to see you still around friend
Old Jan 25, 2009 | 09:12 PM
SpecterGT260's Avatar
Ninja Administrator
yet they hold up to a 281 just fine
we dont exactly need biased misinformation. just because the t5 isnt as good as the t56 doesnt make it complete garbage. you can run easy 12s on the t5, or at least the one that came in the mustang.....
Old Jan 27, 2009 | 09:13 AM
JD1969's Avatar
I am running a B&M cooler that I have had on a few cars, I forget what the model number is, but it was the biggest one I could get at the time. Remember thoguh that its a lock up converter, so when you are just cruising around there is not really that much heat generated. Yea I know I have been MIA for awhile. Work is super busy during the winter months and now we have two kids, so they take up more time. I will be around a lot more once the snow melts.
