LS Series Tech 1998-2002
1999 Camaro with v6 to LS?
Old Apr 19, 2020 | 08:59 PM
Beaky73's Avatar
Default 1999 Camaro with v6 to LS?
Hello All, I have a 2005 5.3 V8 out of a Silverado that I was going to put in an 87 T/A. i am now rethinking and may get a 99 Camaro with a V6 and swap the motor. my question is, will the 4 speed mate to the V8? i am guessing no but want to double check... also i saw a 5 speed 99 Camaro with a V6 and I know the trans will not work with the V8 but will the clutch system work with T56? Thank you All
Old Apr 19, 2020 | 09:51 PM
Way more trouble that it's worth is the short story,gets asked here often.
Old Apr 20, 2020 | 06:41 AM
No the V6 trans will not work with a V8, Different bolt pattern.
No part of the T5 clutch system will work on a T56, its a completely different release system and different size.
Go back to your original plan. For the 99 you need a v8 frame and custom wiring harnesses to get anything to work on the inside.
He over to the V6 section there is a V6 to V8 thread, at the end of that there is a link to someone who did, you can see what all is involved.
ch3vyman816
May 5, 2018 06:24 PM
willef99v6
Jul 29, 2009 01:09 AM
alexval2121
Jul 9, 2007 02:08 AM
ShawnGP
Mar 5, 2007 12:18 PM
serensdipity
Jan 25, 2006 07:35 PM
