TPI setup
ok,ive been looking arounda nd i want to do a TPI setup to my engine that im (slowly) building
its an 86 350
its got head casting number (14011083)
not really sure if thats needed,but im going to do a t-5 swap as well,what ive understood is its only used on an auto tranny,how can i make this work withought using the auto?
does anyone have a link to doing this swap?
and something about an anti theft device?
mainly just looking for some direction here
its an 86 350
im not sure if this matters,but im not actually putting this into a camaro,im putting it into a diffrent car,i just need to get the engine working on its own,i was looking at a painless wiring kit,but that thing is 400 bucks
Is there any reason you are trying to go Fuel injection? It would be much cheaper to run a carb set up. Also i would not waste your money on a T5 swap.
ORIGINAL: cbr600rx7
ya, im throwing my 350carb into a late 80's mazda rx7 that ive had sittiting around,and for the 5 sp,its better to have a manual in atuocross/drifting anyways
i just need to get the system to work,i dont need speed sensors etc,i already have all that worked out,just need to go FI,or a carb that can tak a assload of hard cornering
Carb technology has come a long way in the last 15 years. A good carb set up will work great even in the twisties. I have a friend with a 350 swap in a 2nd gen and its a fun little car. But you need to stay away from the T5 its crap to start with and will be useless to you.
