Can't put filter oil on CAI?
Old May 11, 2009 | 03:41 PM
BiNuX's Avatar
Default Can't put filter oil on CAI?
I cleaned out my CAI and then used k&n filter oil and the car ran like total garbage, took it off and cleaned it again then slapped it on and ran fine, i thought you were supposed to use oil on these? maybe not! input?
Old May 11, 2009 | 03:47 PM
yes u are supposed to use oil on the k&n. as little amount as u can and still cover it. then let it set for a while to dry or drain the oil off. the oil in them will mess with your sensors if u over do it.
Old May 11, 2009 | 09:02 PM
KingDumpty's Avatar
yea m8 if you don't let it sit and dry for a while after being cleaned and oiled it wont run properly, after you clean and oil it you should let it dry for a few hours
Old May 14, 2009 | 12:38 PM
libertyforall1776's Avatar
Yes, you have to let the oil dry for about 4 hours -- read the instructions ;-)
Jared Cassedy
Nov 28, 2010 10:56 AM
Spartan66
Dec 12, 2008 11:55 AM
jason7504
Aug 19, 2008 12:50 PM
dubon89rs
May 29, 2007 01:15 PM
Deagle85
May 6, 2007 12:38 AM
