89 RS camaro dual exhaust...
Old Jan 7, 2007 | 05:07 PM
gozzy341's Avatar
Default 89 RS camaro dual exhaust...
Alright, i got a 1989 RS camaro with a 305 v8, sad to admit that the exhaust is... quite pathetic. It has two manifolds, one pipe, one catalatyc converter, one muffler, and two tail pipes. Its what you would call a "cross over exhaust". I would like to put a true dual exhaust in this with headers, however the only problem that stands is that the car is so low to the ground and the way it is set up im not sure if there would be enough room for two mufflers. Im worried that if i hit a bump ill ruin my exhaust. If anyone has converted a cross over exhaust into a true dual exhaust in a similar car, could you help me out here? Let me know if i can convert it to a true dual exhaust. Thanks.
Old Jan 7, 2007 | 05:08 PM
shnormo's Avatar
Default RE: 89 RS camaro dual exhaust...
How much ground clearance you got? You can use a set of Hushpower mufflers from Flowmaster. They are smaller than the standard mufflers.
Old Jan 7, 2007 | 05:10 PM
gozzy341's Avatar
Well i want to put cherry bombs for mufflers. I realize taht these mufflers are smaller. I got roughly 6 inches of clearence
Old Jan 7, 2007 | 07:05 PM
blackz87's Avatar
You have a stock factory exhaust system. A dual systems is not worth it.
jdfronek
Apr 20, 2008 10:00 AM
jason14227
Dec 26, 2007 11:48 AM
rockin85
Aug 1, 2007 10:41 PM
aray
Jun 12, 2006 12:33 PM
