What motor fits?
Old May 11, 2006 | 12:14 AM
benz660r's Avatar
Default What motor fits?
Just wondering what motor will fit into my 1979 camaro. Not lookin new looking to rebuild a motor but dont know what motors from what year cars will fit? Will they bolt in or what do i need to do to make it fit?
Old May 11, 2006 | 02:10 PM
dzroc's Avatar
Default RE: What motor fits?
you can pretty much put in whatever you want! thats the beuty about older cars.Big block, small block v6 or v8.the only thing you might need to change are motor mounts.i recomend a small block 350.alot of hp for little money.Need more details?? let me know.
Old May 11, 2006 | 06:50 PM
benz660r's Avatar
is there a book or fact page i can look at to see whats involved with putting what motor in? How hard would a 400 truck motor be to fit in there?
Old May 11, 2006 | 07:01 PM
bowtieguy's Avatar
July 2009 ROTM
like he said any motor will fit in that car.i got a 454 in my 78 camaro.it fit right in there.the only thing that was a problem was finding the right headers and really that wasn't that big of a deal,summit hooked me right up.there is no book to tell you what fits what.read some hotrod magazines and look at what they put in cars.any motor will fit in that car.265,283,305,327,350,400,396,454,502,572 pick one it will fit
Old May 11, 2006 | 11:55 PM
benz660r's Avatar
i was looking into a 350 or 454 if i could fit it? WHat did you have to do to make your 454 fit inside the camaro. It came with a 305 orginally but i dont know if that matters?
Old Sep 17, 2006 | 11:38 PM
cpetitclerc73@hotmai's Avatar
What needs to be done to Upgrade a original V6 to a 350 V8. Looks like the tranny, the brakes and etc etc. Its the wiring harness is different. The only part I'm worried about and the tranny I heard needs a tilt braket moification piece for my 85 Camaro. Also the bakes and any different part code found at the part store nearest you. Could get expensive. Any Feedback would help
Old Sep 18, 2006 | 12:32 PM
1969 SS's Avatar
ORIGINAL: benz660r
everything will just be a bolt in. you can even still use the same mounts, but if you do, you might have to elongate the holes in the frame where the crosssmember bolts in because the big-block mounts fractions of an inch different that a small block. you shouldn't have to woory about your driveshaft though. also you need to get new coil springs
good luck
Old Sep 18, 2006 | 12:38 PM
1969 SS's Avatar
ORIGINAL: cpetitclerc73@hotmai
you will need to change your engine mounts first off. the tranny will need to be changed because it probably won't last (what is in there now?) but I don't know what you are talking about with a "tilt bracket?", where did you get that info because it sounds like a Mickey Mouse fix if you are taking a shortcut somewhere else. your driveshaft length will need to be fixed, front springs to handle the heavier block, the rearend is probably too weak. your brakes are fine becuase they have nothing to do with the engine size. Street and Performance, Painless Wiring, Ron Francis and others have wiring kits for the conversion that you are doing
good luck and give updates if you decide to do it
Old Oct 3, 2006 | 04:19 PM
uncle bill's Avatar
Lots of room under there for about any motor all the way up to a 502.
Old Oct 3, 2006 | 08:24 PM
MadMikeZ28's Avatar
I personaly would go ***** out and get a 572
SandysLT1
Feb 13, 2012 04:25 PM
Mr. Jones
Nov 12, 2009 07:30 AM
koesdibyo
Nov 30, 2007 06:19 PM
VQMaxFan
Jun 22, 2007 05:40 AM
D83ZAdams
Mar 9, 2006 01:11 AM
