weird hum coming for underneath the car
Old Mar 1, 2007 | 01:15 AM
Matt99camaro's Avatar
Default weird hum coming for underneath the car
I've got a 99 3.8. This weekend I started hearing a humming noise inside the car.When I checked it out further it seems to be coming from underneath, somewhere around the rearend. The tone changes when I accelerate and brake. From inside the carit almost sounds like engine noise going throuh a sound system and I thought that is what it was at first, but it is deffinately coming from under the car. It's not a whining sound like a tranny going out, I know that sound all to wellAny ideas what it could be?
Old Mar 1, 2007 | 01:20 AM
ghotachevy's Avatar
Default RE: weird hum coming for underneath the car
u joint ring and pinion? axle bearing ur brakes dragging
Old Mar 2, 2007 | 12:32 AM
microkid's Avatar
March 2011 ROTM
Technical User
tranny rear bearing, u joint, rear end gears or bearing, or maybe brakes. drum or rotor brakes? my brother had the same sound comming from his 86 suburban with a 4l60e, and it ended up being a u joint because it blew out on a speed bump
Old Mar 2, 2007 | 11:19 PM
bluovlh8er's Avatar
on the 95 i had it was the berring that is where the drive shaft connects to the rear axel.
onefastls1
Jan 2, 2013 01:45 PM
305_camaro
Jun 13, 2012 02:45 PM
94ChevyCamaroV6
Oct 1, 2011 11:44 AM
unoste
Jul 5, 2011 03:55 PM
Avery
Nov 15, 2010 12:34 AM
