Tubulor control arms with adjustable panhard bar
Old Mar 15, 2012 | 08:02 AM
Cliff123454321's Avatar
Default Tubulor control arms with adjustable panhard bar
What is it and what does it do? and what's adjustable about it?
Old Mar 15, 2012 | 07:50 PM
The tubular control arms replace the factory stamped steel ones. If properly built, the tubular arms should be stiffer and control the axle better. The panhard bar holds the rear axle housing from moving side to side under the body of the car, and more importantly keeps the axle from going its own way. If the ride height of the car is changed the rear axle housing will shift sideways under the car. The adjustable type panhard bar can be adjusted to bring the axle back in center.
tex_02
Jan 17, 2013 07:56 AM
redemption91
Oct 27, 2010 01:31 AM
cchoneycutt
Dec 30, 2009 06:23 PM
1lowryd
Mar 17, 2009 06:45 PM
jarid2000
Apr 23, 2006 08:46 PM
