Trunk Pull-Down Hatch Assembly
Old May 10, 2008 | 04:16 PM
matthew9440's Avatar
Default Trunk Pull-Down Hatch Assembly
I have a 1991 Camaro RS 3.1 L V6. The trunk latch broke and I went on ebay and I got another one that was taken off of a 1986 Iroc-Z. The one from the Iroc has like a different looking mechanism and when I hooked it up there was one wire that I couldnt hook anywhere, and it hooks but it doesnt suck down like it should. Is there anything I can do to make it work. I am sick of riding around with the hatch bungeed down.
Old May 10, 2008 | 04:56 PM
blackz87's Avatar
Default RE: Trunk Pull-Down Hatch Assembly
86 and your 91 hatch assemblies are as different as night & day. It is usless to you. Go to the web site of Top-Down Solutions and get the info there. They also have full instuction you can down load for the hatch repair. Good luck
Old May 12, 2008 | 08:07 PM
carkook's Avatar
I have that same car, and had the same problem. I went to the pick n pull and got the whole assembly and replaced but there was also one wire that didnt go anywhere... I dont know what it was for. If the other mechanism is somewhat alike you can take the motor out, spin the thing down a bit then put the motor back in, In doing this it is more pulled down already while the motor has not closed it yet(if that makes since?)
concept225
Dec 25, 2009 07:28 AM
JSmith7x
Nov 2, 2009 12:16 AM
bd92rs
Apr 24, 2009 07:50 AM
chevydrvr
Feb 13, 2009 09:36 PM
sd9010
82-92 V8 Tech
Jun 28, 2008 03:20 PM
