87 Iroc-Z rear hatch won't pull down
Old Apr 20, 2008 | 05:32 PM
sd9010's Avatar
Default 87 Iroc-Z rear hatch won't pull down
Hello everyone.
I am new to this site, and have a problem with my rear hatchn on my 87 Iroc Z.
I just got my car out of storage, and when i opened my hatch the motor kicked on and raised it, but now it will not lower it.
The striker latches but will not pull down my hatch.
Is this an electrical problem? Or is it a bad motor?
Thanks in advance for any suggestions
Scott
Old Apr 22, 2008 | 05:13 PM
sd9010's Avatar
Default RE: 87 Iroc-Z rear hatch won't pull down
i was also wondering if I could put a manual latch in instead of the electric one.
Old Apr 22, 2008 | 05:58 PM
MadMikeZ28's Avatar
There is a switch on the latch that the striker comes in contact with that may have gone bad. The switch moves with the latch and the wires are small and break.
A manual latch makes the hatch hard to close
Old Apr 22, 2008 | 06:34 PM
adirtypoostick's Avatar
From: IN, or hell whichever, wait, its too cold to be hell
check your relay, it should be attatched directly below your latch assembly. It may have gotten moisture inside of it. The same exact thing happened to me and it was just a 10 dollar relay instead of the 150 dollar assembly I bought.
Old Apr 22, 2008 | 10:03 PM
buckfever's Avatar
mine was messed up so i just disconnected it and use it as a manual one
Old Jun 27, 2008 | 07:12 PM
DieFast's Avatar
mine did the same thing. so after tearing apart the motor and messing with it i found that the thing was spitting gear teath. a brandnew rearhatch motor costs about 180 bucks so have fun.
Old Jun 28, 2008 | 10:18 AM
sd9010's Avatar
Thanks for all the help.
I put a new motor in and it did the same thing. The new motor was only $75.
I ended up just unhooking the motor and making it a manual one.
Old Jun 28, 2008 | 03:20 PM
MadMikeZ28's Avatar
HAH! I found one at a pull a part and it was $5. It pissed the cashier off that there was no other listing fro rear latch when she saw it had electrical and a motor on it so she could not charge me more.
concept225
Dec 25, 2009 07:28 AM
JSmith7x
Nov 2, 2009 12:16 AM
bd92rs
Apr 24, 2009 07:50 AM
chevydrvr
Feb 13, 2009 09:36 PM
matthew9440
May 12, 2008 08:07 PM
