TRANSMISION ?'S
Old Dec 1, 2007 | 10:44 PM
Custm72chevy's Avatar
Default TRANSMISION ?'S
im need help.
will a muncie 4-spd, like a M-21, bolt up to a 305 c.i.out of a 1984 Z-28?
the reason i wanna know is 1. my car now is a 3 spd automatic.
2. i want a manual transmission(i was thinkin bout savin up for the Tri-5 chevy 5 or 6(double overdrive)speed conversion)
3. i love 4 speeds.
THANKS!
Old Dec 1, 2007 | 11:41 PM
MadMikeZ28's Avatar
Default RE: TRANSMISION ?'S
The V8 bellhouse will bolt to any Gm V8. But are you sure you have a 3 speed auto now? Its not a 4 speed 700R4? If it was swapped you will have to see what was done for the torque arm mount.
Old Dec 2, 2007 | 02:20 PM
if its a 4 speed ive lost 4th gear...idk i jus know the guy we bought it from rigged the whole car and were finally gettin through most of his riggin
Old Dec 2, 2007 | 07:34 PM
MadMikeZ28's Avatar
well if you have a 700R4 like what should be in there it would have a 16 bolt square pan and a 4 wire plug going into the tranny close to the tail shaft houseing
Old Dec 6, 2007 | 06:37 PM
alright ill check it out tomorrow in auto tech..i think it is a 700r4 if its got a square pan..cause i THINK its got a square pan..i aint had it on a lift since i bought it..jus up on stands and i never payed particular attention to it
vid619
May 5, 2012 06:18 PM
jason scrapper
Mar 29, 2011 03:33 PM
tbl76camaro
70-81 Transmission & Differential
Nov 15, 2010 03:40 PM
kyleb
Jun 9, 2007 05:54 PM
motor tec
Nov 1, 2006 01:59 AM
