will these rims fit?
Old Dec 3, 2007 | 02:09 PM
bluovlh8er's Avatar
Default will these rims fit?
torq thust 2's with this size..... will it fit a 95 camaro???
Rim Diameter (in): 17 in.
Rim Width (in): 9.50 in.
Backspacing (in): 6.500 in.
Offset (mm): +32.00mm[/align]
Old Dec 5, 2007 | 12:45 AM
95slvrZ28's Avatar
Default RE: will these rims fit?
They should, the 17X9.5 is good, you may want to check the stock backspace and offset on a set of OEM 17X9.5 vette wheels and compare the two.
Old Dec 7, 2007 | 11:32 AM
t9ojetpilot's Avatar
[&:] blu ovl the offset for stock is 56 mm so these should work. they may not allow for the largest tire wheel combo possible under the car though if your looking for max grip and footprint. may want to do some measurements on your car. this may put some of the tire at the edge or sticking out of the fenderwell and depending on aspect ratio (40, 45, 50, 60 etc) of tire used may even have some rubbing issues especially up front kurt
luciora
Apr 12, 2010 08:18 PM
keith197431
May 29, 2009 07:34 PM
spisak
16
Nov 13, 2008 08:16 PM
94 z28
16
Feb 24, 2008 02:31 AM
90blackrs
Nov 25, 2007 11:20 AM
