Throttle Position Sensor Trouble Code, Help
Old Aug 7, 2007 | 10:29 PM
73 T Top's Avatar
Default Throttle Position Sensor Trouble Code, Help
my check engine light comes on and when i check diagnostic codes it comes up with code 21 which is the throttle position sensor. what could be wrong with it? the motor runs fine. The timing might be off. would timing effect throttle position sensors?
its a 1991 Throttle Body Injected 350 thats in my 1973 Camaro. Its wired up with a painless wire harness.
Old Aug 7, 2007 | 11:02 PM
Goodfella's Avatar
Default RE: Throttle Position Sensor Trouble Code, Help
faulty sensor perhaps?
remove the sensor and check to see if it glides smoothly in its operation, or if it grabs.
auto parts stores might have em otherwise ebay or dealership.
Old Aug 8, 2007 | 12:52 AM
73 T Top's Avatar
ok, i will check that out tomorrow, thank u
Old Aug 8, 2007 | 07:01 AM
bluovlh8er's Avatar
if it says that the censor is bad replace it.
mezzyshredder
May 20, 2012 06:03 AM
chewybacca11
Sep 12, 2010 07:23 AM
kimbers99camaro
Jun 13, 2010 09:20 PM
jfoote
Jan 21, 2008 07:31 PM
z28pete
Aug 29, 2007 10:32 AM
