starting problem
Old Aug 19, 2005 | 09:05 PM
87irocz's Avatar
Default starting problem
hello, i am having trouble with starting my 87 iroc-z the batterie isnt dead but it will not turn over it was running fine yesterday but i discovered a little switch undernieth the dash ani flipped it and my brother said that could have done it. I dont know can someone please help me the switch was next to the fuse door. please. thanks a lot.
Old Aug 19, 2005 | 10:29 PM
Default RE: starting problem
The car may have an aftermarket antitheft gizmo and by flipping the switch you activated it and disabled the car. Flip the switch back & see if it cranks.
Old Aug 20, 2005 | 01:18 AM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
its usually called a valet switch i think...try flipping the switch and turning it over
Old Aug 20, 2005 | 09:57 AM
87irocz's Avatar
i flipped it back still nothing i will try jumping it today.
Old Aug 21, 2005 | 10:41 AM
87irocz's Avatar
nothing guys please help me!!!!
Old Aug 21, 2005 | 02:04 PM
It could be the alarm system or a bad starter/solenoid, or may be wiring.
Do a quick checck for the starter:
1)With everything off, check the voltage between the battery cable terminal on the starter and frame ground, should be at leat 12v. If not check the battery cable to the starter.
2)With someone turning the key to the start position, do the same thing between the solenoid terminal on the starter and ground, (usually a small yellow wire) should be around 12 volt. If no good check the path between the ignition switch and starter solenoid. Look for splices. rerouted wires, extra relays, etc.. that may be leading to the alarm unit.
3)If both checks are OK, use a large screwdriver and short the solenoid and starter cable terminals on the starter. CAREFUL NOT TO SHORT to GROUND!! WEAR SAFETY GLASSES!! (you don't want to get sparks in your eyes, or melt your screwdriver or cause fires). The solenoid should kick in and the starter should engage and try to turn over the motor. If not you got a bad starter.
Old Aug 21, 2005 | 09:53 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
check the fusible links and battery cables, they are the cheapest place to start getting into wiring issues
Old Dec 21, 2005 | 11:19 PM
mattvogt's Avatar
fusible links, get a chiltons and use that for reference. it will help greatly. good luck with this problem
biggin59
Jul 2, 2010 12:22 PM
PressyP
Jul 31, 2009 03:54 PM
Z28beast
82-92 V8 Tech
Oct 14, 2008 09:37 PM
typeomang
Apr 13, 2008 08:59 AM
Fishy Dave
Oct 9, 2006 09:59 PM
