blow off valves
Old Dec 17, 2005 | 07:52 AM
gandalf's Avatar
Default blow off valves
do i need a turbo kit or any type of turbo for blow off valves...or can i have a stock 3.8L engine and put blow off valves on it
Old Dec 17, 2005 | 11:08 AM
RatedZ's Avatar
Default RE: blow off valves
You need forced induction to use a bov.
Old Dec 18, 2005 | 06:46 AM
gandalf's Avatar
wat if i get an intake for it...will that do the same or do i have to get air induction
Old Dec 18, 2005 | 10:14 AM
Lee Willis's Avatar
It makes no sense without boost. I suppose you could install a blow off valve on your car's intake, somehow, even if you didn't have a blower, but it would not do anything. Blowoff valves only work when the intake pressure exceeds some pre-set pressure (most are adjustable). You have to set that pressure limit at OVER normal atmospheric pressure (i.e., at some level of boost) otherwise the vallve would stay open all the time (or alot of it) and you car would not run at all.
I'm puzzled as to why you would want this? Do you just want the sound?
Old Dec 18, 2005 | 07:41 PM
gandalf's Avatar
yea basically for sound
Old Dec 18, 2005 | 08:44 PM
JD1969's Avatar
ORIGINAL: gandalf
Sorry dude but that is rice
Old Dec 20, 2005 | 03:28 PM
Won't get much sound out of it, unless tehe engine is spitting back like a SOB. Blow off valves are used to prevent damaging a supercharger in case of over pressure, usually due to a backfire. You are probably thinking of a wastegate valve, which routes the exhaust around a torbocharger turbine to hold the boost down. Either way, they will not do anything in your case. A choked up muffler will give you the hissy turbo sound, if that is all you want.
Old Dec 23, 2005 | 05:32 PM
mattvogt's Avatar
why would you like a blow off valve if you have no need for it. spend your money on something useful
Derek Tackett
Dec 9, 2013 06:47 PM
emptysmile005
Feb 16, 2011 01:07 PM
Frankenstein
67-69 V8 Tech
Jul 7, 2010 06:28 PM
Orion
Jul 23, 2009 11:30 PM
94CamaroSFI
Nov 4, 2006 06:28 PM
