running problems in the upper RPMs
Old Jul 28, 2010 | 08:28 PM
wes232323's Avatar
Thumbs down running problems in the upper RPMs
i'm new to the forum so its nice to be here. I traded 91 silverado for a 95 Z28 that has running issues. let me explain.
The car will start and idle perfectly. It will also drive okay on short runs. any more than 1/2 throttle will kill the motor and shut off. after a few moments it will start up and drive again, but for a short distance. When in park, if I hold the throttle @ 3000-3500 RPM the tach will 'flutter'.
the guy hands me reciepts for just about every fuel component on the car, including the fuel pump and injectors, but not the regulator. I get under it and the oil level sensor wires are cut and twisted together. i fixxed that. even put new sensor in. I have a few spare parts but i'm stumped. any ideas?
update: after quick test run to see if what i was reading was what was happening to my car, they seem to be the same with the new oil level sensor no service lite comes on.
really stumped. Knock sensor??? IAC???
Old Jul 30, 2010 | 12:27 AM
have you had it scanned for codes? hate to say this but how old is the opti?
Old Jul 30, 2010 | 08:35 AM
wes232323's Avatar
opti was changed in march. its one of those stupid 95s that is obd1 with the obd2 plug. i do not have any ses lights or anything.... opti huh....
Old Jul 30, 2010 | 10:29 AM
do you know what kind of opti was used? where it came from?
Old Jul 30, 2010 | 11:39 AM
wes232323's Avatar
not sure. just got the car last week. i traded my wrecked 91 silverado 2500. its a nice car and i really want to see it on the road
Old Oct 29, 2010 | 01:00 PM
gregsta565's Avatar
had the same problem, just fixed it, was one bad injector, was working so it idled fine and drove fine until about half throttle, and was gettin bad gas mileage, i replaced plugs, wires, coil packs, fuel filter and fuel regulator, and it was injectors, so replace these things if they havnt been already! then i would replace the fuel pressure regulator! then do a fuel pressure check, if thats good, you may want to do a compression check just to rule that out! but other than that could be a vacuum leak, maf sensor, cam positioning sensor, clogged cat, or maybe bad air filter! get a repair manual and a voltmeter, or google it and you can test alot of the sensors and injectors with the voltmeter!
Old Oct 29, 2010 | 01:11 PM
it was the opti on wes's car. tells it in another thread.
Chrisd0729
Oct 14, 2013 10:02 AM
95greenz28
Apr 25, 2010 07:01 PM
cwj82052
Mar 28, 2008 10:58 PM
crusherdrivinfool
82-92 V6 Tech
Dec 4, 2007 12:42 AM
OZZmobile
LS Series Tech
Dec 2, 2007 11:20 AM
