Reverse Syncronizer
Old Jul 25, 2005 | 04:46 PM
mikeyanni05's Avatar
Default Reverse Syncronizer
If the reverse syncronizer is bad could that cause reverse to slip out of gear and grind?
Also, My first gear grinds while I take of from a stop, it did not do this when i got the car and we know it is not the clutch, it stays in gear and the grinding goes away after accelerating. Do you feel this could be a bad gear? Please post any suggestions.
Old Aug 11, 2005 | 12:19 AM
Default RE: Reverse Syncronizer
What car & transmission do you have? Does first gear grind when you are trying to shift into it. or does it grind while the car is moving? Your clutch may not be relasing fully causing you to grind gears. Otherwise you have a problem. Jumping out of reverse is kinda odd. It could br the synchro, or possibly the shifting mechanism.
skinut
Apr 11, 2015 01:43 PM
chevycrazy32
Mar 26, 2011 09:27 PM
boylemyster
Sep 5, 2010 12:14 PM
bryans3.4 95
Oct 27, 2008 12:40 AM
69dmz
67-69 V8 Tech
Oct 19, 2008 09:26 PM
