Reman a/c compressor
Old Sep 3, 2006 | 02:29 AM
92camsilboat's Avatar
Default Reman a/c compressor
Just bought a reman a/c compressor for my 92 RS v6. I put it in and noticed the a/c lines are different than the backside of the housing. The housing has 2 holes, 1 bigger in diameter than the other and one deeper than the other. My lines are the same diameter and have the same slighty raised mounting surface to fit into the depth of the holes. So i took it back and had them look up the numbers again and check another compressor out with the same numbers...got the same results. I understand that reman parts are fitted to work with mutliple applications but does anyone know of any adapters that are out there for this?
I also ran the a/c lines, and found them to be the same as I already have in the car. Its a Ready Aire a/c compressor bout through AutoZone.
Thanks,
Bobby
Old Sep 3, 2006 | 07:06 AM
MadMikeZ28's Avatar
Default RE: Reman a/c compressor
There should have been the seal kit that has adapters and instructions with the compressor. You compare a picture to the manifold you have and it tells you what seals and adapter to use.
Old Sep 3, 2006 | 12:41 PM
Nothing like that came with the pump. I had to buy a bag of assorted seals. But what i relly need is an adapter for it. Any ideas?
Old Sep 4, 2006 | 05:13 AM
MadMikeZ28's Avatar
Go back to Autozone and tell them the seal kit was not in it. These have been in the box with every compressor I ever bought.
Old Sep 4, 2006 | 01:53 PM
Ill do that, but all the other boxes that we opened up to compare with didnt have any seal kits with them either.
Old Sep 4, 2006 | 08:59 PM
MadMikeZ28's Avatar
Come to think of it I might have only ever used one reman compressor. If memory serves it was junk and I said never again. good luck with yours. Look at the pick and see if any of the picks look like yours.
[IMG]local://upfiles/4028/8E87BF5BC4B442168AC10724E76901F8.jpg[/IMG]
mike6208
Aug 1, 2011 04:17 PM
microkid
Sep 23, 2010 08:26 PM
