recomended tire psi?
Old Jan 12, 2007 | 08:14 PM
microkid's Avatar
March 2011 ROTM
Technical User
Default recomended tire psi?
im running 215/60-15 up front and 255/60-15 on the rear. im concerned about my rear tires wearing out in the center prematurely, which has happened to me befire with another car, and the tires that came off were the same way too. i think the tire might be too wide for the rim, but i dont think it would be. stock size rims, just aluminum. im running 30 psi now in the rear tires, and 38 up front. i left a patch of rubber at school, and it seems like there is only about 4-5 inches of tire making contact on the ground.
Old Jan 12, 2007 | 08:24 PM
ghotachevy's Avatar
Default RE: recomended tire psi?
run them at 35 when you burn out tire elongates hense the reason for the narrow patch
Old Jan 12, 2007 | 09:41 PM
The 255s need at least an 8" rim, 9" would be better. The narrow rim is going to force the center out and make it wear out faster. Excessive pressure will just make it worse, low pressure to correct the problem will make for bad handling. The only tires that stretch safely at high speed are drag racing slicks, because they are especiallly constructed to do it. If you street tires are doing that, you are spinning them too fast and will soon blow out.
Old Jan 13, 2007 | 12:55 PM
microkid's Avatar
March 2011 ROTM
Technical User
what size would the stock rims be?
Old Jan 13, 2007 | 01:06 PM
They came in various sizes, depending on options. The rim size is usually marked on the rim.
Old Jan 14, 2007 | 01:53 PM
microkid's Avatar
March 2011 ROTM
Technical User
ive got aftermarket rims on my car, and they are aluminum. i dont think there are any marks on them at all. i think i will look back in a newspaper where i saw a set of race tires and rims for a second gen for $80
Old Feb 4, 2007 | 05:10 PM
microkid's Avatar
March 2011 ROTM
Technical User
ive got it down to where i feel is good. 30 psi in the rear and 38 in the front
jordan
Aug 11, 2010 09:03 PM
fearbunny
Jan 18, 2010 07:59 PM
scottybuck
Jul 20, 2008 06:28 PM
Billy
Jun 13, 2007 04:09 PM
o2camaross
LS Series Tech
Feb 24, 2007 02:09 AM
