Rear end humming
Old Mar 17, 2010 | 08:35 PM
mitchell's Avatar
Originally Posted by microkid
then try running another set of gears. i was taught though to set the tooth pattern to the bottom 1/3 so that when the iron flexes from heat and load, its an even contact.
also, in your dash, you will see some ***** and buttons. the upper left ****, turn it clockwise until the sound goes away
hey idk who taught you but if you brought it to a professional he/she would set the contact pattern right in the middle. That is the proper way to do it, I have never heard of that 1/3 to the bottom thing. (and before you argue about what the professionals do, keep in mind, I am one)
Old Mar 17, 2010 | 10:48 PM
White94Z28's Avatar
i had this same issue on my old 76 chevy pickup, i had the truck for over 2 years and the entire time i had it the rear end made a squealing sound that was actually kinda loud it had the big corporate 14 bolt rear end and i checked the diff. fluid multiple time and it was fine but i never did figure out what the problem was. someone told it was because the rear end was crooked and sat alittle further back on the driver side then it did on the passenger side, but i didnt think that made sense because the tires did wear unevenly.
Old Jan 4, 2011 | 11:47 AM
IGTX4LIFE's Avatar
Is the gears...if there are Richmonds, I had those 3.73 and did the same thing and were putting by the local hot rod shop and feel they were done correctly. I called Richmond and they said to expect at little noise from there gears.. price to pay, i guess
avenger900
May 5, 2012 07:30 AM
jasunf
Jun 9, 2011 03:38 PM
19IroczCamaro87
82-92 V8 Tech
Aug 23, 2010 10:18 AM
SS_2000
LS Series Tech
Mar 26, 2010 08:31 AM
ryanh_3
May 20, 2007 11:51 AM
