Nozzle near Distributor?
Old Nov 30, 2010 | 09:37 PM
uestraven's Avatar
Default Nozzle near Distributor?
I have a 81 camaro with a 350. There is a bronze nozzle on the back of the block next to the distributor which im not sure the purpose of. when it is not blocked off it squirts oil out when the car is running. just wondering what this nozzle is?
Old Nov 30, 2010 | 11:31 PM
If you're talking about on the edge of the block, directly behind the intake manifold, that's an oil pressure port. Sounds like you have a fitting there, which would have been connected to a manual oil gauge. Or a pressure switch (sending unit) can screw in it's place, for connecting an electric gauge instead.
Old Dec 1, 2010 | 11:26 AM
uestraven's Avatar
can you suggest any parts i need for that? i know what your talking about but im not sure what to do about it.
Old Dec 1, 2010 | 11:47 AM
Do you currently have an oil gauge, and is it hooked up/working? If you have one but not hooked up, is it electric or mechanical? Which type you have determines where to go from here. I don't spose you can post a picture of the "nozzle" that's on the block?
Old Dec 1, 2010 | 02:32 PM
uestraven's Avatar
Old Dec 1, 2010 | 03:57 PM
That's a small tubing fitting for a mechanical gauge. Hard to tell, is that a solid plug or a nipple fitting at the end?
Old Dec 1, 2010 | 05:16 PM
uestraven's Avatar
its completely solid
moose69
Mar 18, 2015 09:23 AM
TG_69
67-69 V8 Tech
Jul 3, 2010 08:43 PM
chevellecamino
67-69 V8 Tech
Dec 23, 2009 06:09 PM
chevy time boy
82-92 V8 Tech
Dec 19, 2006 12:45 AM
btrux06
Dec 3, 2004 08:27 AM
