New Carb Less power need some help!
Old Mar 31, 2009 | 04:50 PM
Danthemanz28's Avatar
Angry New Carb Less power need some help!
Hey hows it goin i juss finnally got my 86 camaro z28 out of the paint garage after 2YEARS of payin off a paint job, but now i have another problem. Before i put it in the garage i put a new carb on it an Edelbrock 600 cfm but now when i speed up its realll slow once i get goin it aint bad but accelaration is terrible, and my check engine lights on. i got people lookin at but we cant figure it out any suggestions.
Old Mar 31, 2009 | 05:06 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
How did it work before it went into paint/storage? I would first look at the fuel, if it sat for a while the fuel could be bad. Maybe a quick tune up (timing test) might be in order.
Old Mar 31, 2009 | 07:53 PM
Default well...
Right after paint it ran out of gas n we had to put new gas into it. so i dont think that thats it. n it ran about the same before goin into paint. but thanks let me know if u have any more ideas
Old Mar 31, 2009 | 07:56 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Even good fuel can go bad after two years.
Could be a vacume leak.
Old Mar 31, 2009 | 08:23 PM
no i put new gas in when i took it out and it ran out when i took it out. but yes i agree on the vaccuum leak because i know that the to vaccuum seals on the front of the carb were dry-rotted right out but do you think that that would be enough to cause that. and i think that it ran just the same with the old carb on it. and i thought the carb was causing this so i bought a new one.
Old Mar 31, 2009 | 09:03 PM
PAzYearazzUP's Avatar
Maybe the ignition is retarded a touch where it runs like it has no pep.
Chase your tail if you do not find that compression across the board. Besides, did you prep the valves that were open for 2 years? Rust on the seat and face of the valve?
Check compression.
Old Apr 1, 2009 | 02:07 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
I agree, check compression. If the fuel is good I suggest doing dome tests. Compression test will tell you alot, as will a vacume test (using ether or starting fluid) I didnt even think of the valves, good call pazz.
shagadoodle
70-81 V8 Tech
11
Sep 30, 2010 11:29 PM
MaxTheKiing
Aug 23, 2010 03:21 AM
albo1989
82-92 V8 Tech
Jul 1, 2010 07:40 PM
Dyermaker14
82-92 V8 Tech
Dec 24, 2007 03:36 PM
