NEED HELP WITH SIGNAL LIGHTS
Old Apr 28, 2007 | 03:31 PM
NITRIS's Avatar
Default NEED HELP WITH SIGNAL LIGHTS
I have 88 IROC
the trouble im having is no signal lights, I have Hazard lights but no signal..
I replaced the signal clicker and still have hazards but no left or right signals.
please help
Old Apr 29, 2007 | 12:15 AM
microkid's Avatar
March 2011 ROTM
Technical User
Default RE: NEED HELP WITH SIGNAL LIGHTS
its more than likely the actual selector. take your plastic of the column, and the steering wheel if nessacary. there should be metal contacts for where the switch hits to complete the circuit. i actually had mine wear through on my geo tracker, and fixed it by wadding in some aluminum foil
Old Apr 29, 2007 | 01:23 AM
MadMikeZ28's Avatar
There are two flashers. One on the fuse panel for the turn signals and one on a convienece center for the hazard. Check the turn signal fuse? Check for power going to the flasher. All your bulbs good? All else fails then it may be your signal switch
Old Apr 29, 2007 | 04:15 AM
NITRIS's Avatar
problem fixed it was the second switch that i didnt see in its hiding spot
sgreg831
Apr 7, 2014 08:03 PM
tangentspace
Feb 10, 2010 12:08 AM
95redz28
Sep 20, 2009 02:21 PM
dustinb
May 1, 2008 06:27 PM
91 RS
Feb 24, 2007 11:14 PM
