Motor seems under alot of load/sluggish
Old Jan 4, 2007 | 12:30 AM
RebelDawgZ28's Avatar
Default Motor seems under alot of load/sluggish
I have a 87 Z28, 305, 5 speed. The car has set up for about a year. I installed a new stock replacement clutch and new plugs. The gas tank had been full when I started it. I ran the tank to about a quarter and then refilled with premium gas and some sea-foam. The problem is that once the clutch is released, the motor/car bogs down like it it under an extreme amount of load. Once the rpms are brought up above 3k to 3500 does it seem to come alive and want to run. Also the car runs with an almost miss at low rpms. If anyone knows of anything I can check or give me a place to start looking, I would appreiciate it.
Old Jan 4, 2007 | 02:35 AM
95slvrZ28's Avatar
Default RE: Motor seems under alot of load/sluggish
Check your EGR valve, sounds like it isn't working correctly, either it's plugged or has gone bad.
Old Jan 4, 2007 | 11:51 PM
microkid's Avatar
March 2011 ROTM
Technical User
possibly a clogged cat as well?
White86IROC-Z
82-92 V8 Tech
Apr 18, 2009 05:10 PM
borisoldier
Mar 4, 2009 01:22 PM
1994greenchevy
Aug 2, 2007 09:29 PM
AnimalCracker
Jul 12, 2007 10:00 AM
chevman00
Feb 3, 2007 12:17 AM
